I installed Zabbix 1.4 on REDHAT ES 64 bit (installed only the Zabbix_server).
The folder of /usr/local/bin shows Zabbix_Sever as the only file being present / installed.
(i wonder if zabbix_get or zabbix_send is also required ?).
I then monitored the same host on which Zabbix is installed.
The log generated the following error.
Any clue guys ??
I also added a few other hosts , but the same error was recieved.
The front end also shows the Availability Option as being Not Available .
Some guidance would really put me on the right track.
3949:20070615:164832 Get value from agent failed. Error: Cannot connect to [192.168.100.45:10050] [Connection refused]
