phtml file... why?
  • selectron
    • May 2007
    • 17
    phtml file... why?
    Hi, All!
    I think that this trouble is simple, but I can't find something about it on Zabbix forum.
    I'm installing Zabbix server in second time. In first time I installed it on other PC. I did some settings, but when I open browser with "127.0.0.1/zabbix" , then I see new window "You have chosen to open
    which is a: PHTML file from 127.0.0.1
    What should Firefox do with this file? etc."
    zabbix_server and zabbix_agentd started.
    What do you say?
    Thanks...
    Sorry for my English...
  • just2blue4u
    • Apr 2006
    • 347
    sounds like a webserverproblem...
    The index page of zabbix is a php file.
    Are you sure you use the correct url?
    Just to make sure: You installed the GUI, didn't you?
    can you post some webserver logs?
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
    • selectron
      • May 2007
      • 17
      Thanks...
      I did error. I copied files in error place.
      At this time ok.
