Applications problem in frontend v1.4 (bug ?)
  • AlexeyHTK
    • Mar 2007
    I have one host with one link to template.
    When I create second template link to the host, all applications on this host from first template was deleted, and added aplications from second template.
    But if I add both template links at once for new host, all applications exists - from both templates.
    I think that all applications from all templates must exist when I add new template link for host with existing links, isnt it?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    You're absolutely right. Actually the problem was already reported and a patch can be found on ZABBIX Forums.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
