[1.4] Bug in hosts groups
  • bobrivers
    • Feb 2007
    • 115
    I was not able to reproduce it again. I don't know the exact order that I did to make it happen. I was in doubt if this post would help or not, so forgive me. Just trying to help...
    I created one host group and added some hosts to it. Then I created a user group and gave READ ONLY rights to the host group created.
    If I click over the "Users rights" I can see that all the hosts that are attached to the host group are now in the read only column.
    So I save everithing and logout. After that I login with another user (common zabbix user), that is tied only with the user group created.
    When I click over "monitoring > graphs", the combobox "group" shows only the correct group, but the hosts combo is empty. Even if I change to all then switch back to the host group, the combo isn't filled...
    I tried to remove the hosts from group then put it back, but the problem is not solved. So I created another group, and repeated the steps that I mentioned, and they worked...
  • bobrivers
    • Feb 2007
    • 115
    Additional info
    Just some additional info: I edited the user group and removed the host groups from READ ONLY and that attached the same host groups to READ/WRITE.
    Using the unplivileged user, I logged in into zabbix and everything worked.
    So, I logout and loged in as admin and changed the user group again, removing from READ/WRITE and put it again as READ ONLY...
    The problem appeared again...
