Zabbix 1.4 and ZABBIX server is running No
  • pinguingilo
    • Apr 2007
    dear..
    I Have upgrade Zabbix 1.1.7 to Zabbix 1.4 On My Server, when i Look at Frontend web base at Report - Status Of Zabbix - ZABBIX server is running No, But when I Look at log file, that zabbix has running, port has been listen...
     26616:20070621:124142 Starting zabbix_server. ZABBIX 1.4.
     26616:20070621:124142 **** Enabled features ****
     26616:20070621:124142 SNMP monitoring:       YES
     26616:20070621:124142 WEB monitoring:        YES
     26616:20070621:124142 Jabber notifications:  YES
     26616:20070621:124142 **************************
     26620:20070621:124142 server #1 started [Poller. SNMP:ON]
     26623:20070621:124142 server #3 started [Poller. SNMP:ON]
     26627:20070621:124142 server #6 started [Trapper]
     26621:20070621:124142 server #2 started [Poller. SNMP:ON]
     26625:20070621:124142 server #4 started [Poller. SNMP:ON]
     26626:20070621:124142 server #5 started [Poller. SNMP:ON]
     26629:20070621:124142 server #7 started [Trapper]
     26634:20070621:124142 server #8 started [Trapper]
     26636:20070621:124142 server #9 started [Trapper]
     26638:20070621:124142 server #10 started [Trapper]
     26640:20070621:124142 server #11 started [ICMP pinger]
     26643:20070621:124142 server #12 started [Alerter]
     26645:20070621:124142 server #13 started [Housekeeper]
     26645:20070621:124142 Executing housekeeper
     26649:20070621:124142 server #14 started [Timer]
     26652:20070621:124142 server #16 started [Node watcher. Node ID:0]
     26651:20070621:124143 server #15 started [Poller for unreachable hosts. SNMP:ON]
     26654:20070621:124143 server #17 started [HTTP Poller]
     26659:20070621:124143 server #18 started [Discoverer. SNMP:ON]
     26616:20070621:124143 server #0 started [Watchdog]
     26645:20070621:124143 Deleted 0 records from history and trends
     26620:20070621:125617 Enabling host [ZABBIX Server]
     26623:20070621:125618 Enabling host [ZABBIX Server]
    How About this ??
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    ZABBIX frontend checks status of the server and the agent by executing 'ps ...'. It seems that your PHP configuration does not allow this.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • testos
      • Apr 2007
      • 85
      In my system, I was fixed it disabling SELinux protection for httpd daemon and restarting httpd daemon.
      • Palmertree
        • Sep 2005
        • 746
        I have the same problem but mine is due to the fact that the zabbix server is running on a different box than the web services. Has anyone found a soution for this type of scenario yet?
        • testos
          • Apr 2007
          • 85
          SELinux protection can be tuned by .pp policy modules files. You can try this
