Database corruption...
  • pbudden
    • Jun 2007
    Hi all.
    I have read with interest the posts regarding the now famous "Database corrupted, missed default user 'guest'" problem.
    I am having that problem and am unable to clear it.
    I have followed steps and patches detailed here and in the wiki to no avail...
    I am sure I must be missing something so any direction someone can point me in will help.
    I have Zabbix installed on CentOS 4.4 it did complain a few times on attempting to install but after fixing the errors and missing deps the install seemed to work without problems.
    I have a MySQL database hosted on another server. I created the user and and database. I populated the database with the three schema files as directed.
    There was an error in the mysql.sql file that is resolved in a post.
    still upto this point all seems good.
    copied/created/edited the relevent config files.
    I created the local zabbix user and launched the zabbix_server and agentd
    no errors in logs.
    when I launch the web frontend the configuration works fine, set the db and it communicates with it.
    Green accross the board.
    After the config I get a blank page that keeps refreshing and the address and httpd logs indicate Database%20corrupted,%20missed%20default%20user%20 'guest'
    help please... what have I missed.
    I have removed all files and the DB several times. then started again perfoming the edits first so there is no errors.
    TIA.
    Paul
