Problem with vfs.file.regmatch
  • Umair
    • Feb 2007
    • 86
    I have been trying to check if a specific String exists in a File using the vfs.file.regmatch function.
    This is how the key of ITEM looks:
    vfs.file.regmatch[/etc/zabbix/text,java]
    with "java" being the Regular expression.
    This function is supposed to return 0 or 1, but does not do any thing.
    Even the logs are empty.
    I tried changing the fucntion to vfs.file.exists, but the same result.
    Any ideas?
    P.S. The user 'zabbix' has read write access to this folder.
  • Umair
    • Feb 2007
    • 86
    Okey, i managed to make it work.
    The only problem i was having was, that i had set the Agent Type to Agent (Active).
    By the way, what really is the difference betweent the two ?
