I've had the same problem; RHEL 4.2 (2.6.9-22);beta1.2, upgraded to beta1.8, still can't get disk_read_ops. Using an ide disk /dev/hda /dev/hda3 neither works. Are you all using IDE as well? Maybe it works with scsi? Does anyone know how to cheat on this? I can't get vfs.* to work either, and I just ended up writing a shell script that got me the info I needed. Is there somewhere in /proc I can get the info instead?
