Remote Command Execution Without Involving Action
  • Umair
    • Feb 2007
    • 86
    Hey Guys..
    Zabbix supports the execution of Remote Commands through a script executed by the Zabbix Action.
    Does it execute Remote Commands directly (wihtout involving Action)?
    So that the Server would initiate the command on the remote host and then recieve the output.
    I can do it using External Scripts (Server Side), but then it would be complicated.
    Is there any way i can execute Remote Command on Zabbix Host and recieve the value through Item and Trigger.
    Regards
    Umair
