host status does not update
  • nick
    • Oct 2004
    hello,
    i found that the host status (0 - normal, 2 - unreachable) usually fails to update. i even have a server restarted without receiving any warning, because i do not receive any updated status. are there any solutions or workarounds? any help will be appreciated.
    nick
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Do you have ZABBIX or SNMP agent running on the host?
    What do you mean saying "usually fails to update"? If the host is down, does ZABBIX show that the host is unreachable?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • nick
      • Oct 2004
      i have installed a zabbix agent on this host. as you can see the host status has not been updated for 7 days. actually this problem exists on all servers.
      DESCRIPTION Last check Last value Change
      CPU utilization 1min 27 Oct 09:45:14 3.80 % +3.17 %
      Disk space free on c: 27 Oct 09:41:51 672.41 MB -
      Disk space free on e: 27 Oct 09:45:20 10.41 GB -
      Host status 20 Oct 07:39:36 0 -2
      Host uptime 27 Oct 09:44:58 7d2h8m54.40625s +5m0.84375s
      icmpping 27 Oct 09:45:37 1 -
      Memory free 27 Oct 09:45:14 380.97 MB -8 KB
      MS SQL Server service state 27 Oct 09:45:14 0 -
      • nick
        • Oct 2004
        i spotted an error today 4/11/04 related to the above issue. the machine is running Windows NT with zabbix agent installed, the zabbix agent failed, which happened occasionally on Windows NT. But when it failed, host status suddenly started to update status to 2, which hadn't been updated for days. when the host status turned to 2, icmpping was either not updated or showed no error.
        the problem is, when the host failed, the host status is turned to unknown, it doesn't trigger the alarm. and even icmpping does not guarantee to update too, so there is no alarm at all in this case.
