guest is not seeing triggers
  • Philippe
    • Oct 2004
    • 77
    i updated from 1.1.6 to 1.4.
    Everything works, still have a lot to do because links from templates were gone.
    But i have the problem that 'guest' is not seeing any triggers, graphs or maps.
    When i log in with a user, i see the triggers.
    guest is in group WEB viewers and web viewers has read only access to everything.
    i added a new screen with a clock, and the guest can see it.
    in that screen i add a graph i made and after that the specific screen dissapears from the menu.
    when i delete that graph in the screen again, the guest can see the screen again...
    When i change that user from "zabbix user" to "zabbix admin", i can see the maps and screens but then i have access to "configuration" and i don't want that.
    Is this a bug ?? HELP NEEDED please, we use this in a operational environment and regular users must be able to contact the screens and maps.
    regards and thanks,
    Philippe.
  • Steltek
    • Dec 2007
    I have the same problem on a Debian System with Zabbix 1.4.2 (1.4.2-4).
    I've tried going through the PHP code to debug this but I'm in way over my head. Does anybody know why this is happening or how to fix it?
    • bgerhardt
      • Jun 2007
      The permissions system is strange.
      To check it go in admin/users/guest
      click show of "User rights (Show)"
      The easiest thing is to use groups.
      You get things just right you might have to play with things like give a user "type user" and give them read/write to the hosts.
      • Steltek
        • Dec 2007
        My guest user (and the guests group it is in) has read only access to everything, including the templates. You mean I need to give it WRITE access to have it be able to view the triggers?
        Update: Indeed, it works now. I guess setting the user/group to 'Zabbix User' is what prevents it from getting to the configuration. Many thanks for the tip, I would never have thought of that!
