I'm having a problem with the latest SVN versions of Zabbix. I had the 1.4 release working all except for getting duplicate messages when it emailed me. Upgrading to SVN fixed the duplicate messages but it broke the whole system. What happens now is that every bit of checked data is the opposite of what it should be. For instance I had some fpings setup in 1.4 that were reporting in the Overview and Map screens properly. Emails, although in duplicate, were correctly sending. After upgrading to svn I checked the graph and it shows the item there correctly but not in overview or maps or triggers. I tested for state change when the item was removed, and it did that ok. Most of zabbix-agent items are also backwards. I think something broke in SVN or I am not compiling right.
I'm using CentOS 5.0 on a 32bit machine with 1gb ram.
Can somebody help me?
Here is my build script: The only thing I am not entirely sure about is the dbsync.h. I had to pull that from another zabbix 1.4 archive because it wasn't available in the svn download.
##Start File: get141
#!/bin/tcsh -f
set NAME=zabbix
set VER=1.4.1
#set SVNDIR=1.4.1svn
set TARGZ=$NAME-$VER.tar.gz
set old_dir = `pwd`
nano zabbix.spec
svn co svn://svn.zabbix.com/branches/1.4.1
mv $VER "$NAME-$VER"
cd "$NAME-$VER"
if ( ! -f include/dbsync.h ) then
cp ../dbsync.h include
endif
aclocal -I m4
autoconf
autoheader
automake -a
automake
cd old_dir
tar cvfz "$TARGZ" "$NAME-$VER"
rm -rf "$NAME-$VER"
./make_zabbix
##End File: get141
##Start File: make_zabbix
#!/bin/tcsh -f
set TARGZ=zabbix-1.4.1.tar.gz
set RSPEC=zabbix.spec
set F1=zabbix-agent.init
set F2=zabbix-logrotate.in
set F3=zabbix-server.init
set F4=zabbix-web.conf
cp "$TARGZ" /usr/src/redhat/SOURCES
cp "$F1" /usr/src/redhat/SOURCES
cp "$F2" /usr/src/redhat/SOURCES
cp "$F3" /usr/src/redhat/SOURCES
cp "$F4" /usr/src/redhat/SOURCES
cp "$RSPEC" /usr/src/redhat/SPECS
set old_dir = `pwd`
cd /usr/src/redhat/SPECS
rpmbuild -ba --clean --rmsource `basename $RSPEC`
mv /usr/src/redhat/RPMS/i386/zabb* /usr/src/redhat/SRPMS/zabb* $old_dir
rm /usr/src/redhat/SPECS/`basename $RSPEC`
##End File: make_zabbix
If these scripts get mangled they are also at http://blog.timberlinedealerships.co...for-centos-50/
#!/bin/tcsh -f
set NAME=zabbix
set VER=1.4.1
set old_dir = `pwd`
nano zabbix.spec
cd "$NAME-$VER"
endif
aclocal -I m4
autoconf
autoheader
automake -a
automake
cd old_dir
rm -rf "$NAME-$VER"
./make_zabbix
##End File: get141
#!/bin/tcsh -f
set old_dir = `pwd`
