I compiled 1.4.1 on Solaris 10 and the server starts, but as soon as I set up a remote host to monitor using the Solaris Template, the server dies immediately. The only error in the log is:
17660:20070703:144051 Query [select min(clock) from history_log where itemid=10048]
17646:20070703:144051 One child process died. Exiting ...
17649:20070703:144051 Got signal. Exiting ...
17648:20070703:144051 Got signal. Exiting ...
17652:20070703:144051 In add_trend()
17652:20070703:144051 Query [select num,value_min,value_avg,value_max from trends where itemid=18569 and clock=1183489200]
17660:20070703:144051 In delete_history(trends,10048,1568846554690,5)
17660:20070703:144051 Query [select min(clock) from trends where itemid=10048]
17650:20070703:144051 Got signal. Exiting ...
17652:20070703:144051 Query [insert into trends (clock,itemid,num,value_min,value_avg,value_max) values (1183489200,18569,1,0.031250,0.031250,0.031250)]
17660:20070703:144051 In delete_history(history,10049,31248262722,5)
17660:20070703:144051 Query [select min(clock) from history where itemid=10049]
17652:20070703:144051 Got signal. Exiting ...
17660:20070703:144051 In delete_history(history_uint,10049,31248262722,5)
17660:20070703:144051 Query [select min(clock) from history_uint where itemid=10049]
17653:20070703:144051 Got signal. Exiting ...
17660:20070703:144051 In delete_history(history_str,10049,31248262722,5)
17660:20070703:144051 Query [select min(clock) from history_str where itemid=10049]
17654:20070703:144051 Got signal. Exiting ...
17655:20070703:144051 Got signal. Exiting ...
17660:20070703:144051 In delete_history(history_log,10049,31248262722,5)
17660:20070703:144051 Query [select min(clock) from history_log where itemid=10049]
17656:20070703:144051 Got signal. Exiting ...
17660:20070703:144051 In delete_history(trends,10049,1568846554690,5)
17660:20070703:144051 Query [select min(clock) from trends where itemid=10049]
17657:20070703:144051 Got signal. Exiting ...
17672:20070703:144051 server #23 started [Discoverer. SNMP:ON]
17672:20070703:144051 In main_discoverer_loop(num:1)
17660:20070703:144051 In delete_history(history,10050,31248262722,5)
17660:20070703:144051 Query [select min(clock) from history where itemid=10050]
17658:20070703:144051 Got signal. Exiting ...
17672:20070703:144051 Query [select druleid,iprange,delay,nextcheck,name,status from drules where status=0 and nextcheck<=1183491651 and mod(druleid,1)=0 and druleid>=100000000000000*0 and druleid<=(100000000000000*0+99999999999999) ]
17660:20070703:144051 In delete_history(history_uint,10050,31248262722,5)
17660:20070703:144051 Query [select min(clock) from history_uint where itemid=10050]
17659:20070703:144051 Got signal. Exiting ...
17660:20070703:144051 In delete_history(history_str,10050,31248262722,5)
17660:20070703:144051 Query [select min(clock) from history_str where itemid=10050]
17661:20070703:144051 Got signal. Exiting ...
17660:20070703:144051 Got signal. Exiting ...
17663:20070703:144051 Got signal. Exiting ...
17665:20070703:144051 Got signal. Exiting ...
17667:20070703:144051 Got signal. Exiting ...
17668:20070703:144051 Got signal. Exiting ...
17669:20070703:144051 Got signal. Exiting ...
17670:20070703:144051 Got signal. Exiting ...
17671:20070703:144051 Got signal. Exiting ...
17672:20070703:144051 Got signal. Exiting ...
17646:20070703:144053 ZABBIX Server stopped
I am using the 1.4.1 agent compiled on Solaris 8, but the server dies regardless of whether or not the agent is running on the remote host.
Any ideas?
Thanks,
Joe
Any ideas?
Thanks,
Joe
