Mass Update -> Bug
  • gymv
    • Oct 2006
    Mass Update -> Bug
    I've noticed a bug on Mass Update feature.
    When I click on Mass Update, and update "Update interval (in sec)", any item which i had set "Use multiplier" as "Custom" is updated as "Do not use" instead of "Custom" even if I don't click on "Use multiplier" while I'm configuring my Mass Update procedure.
    I'm using Firefox 2.0.0.4 and Zabbix 1.4.1. I have noticed the same behavior on Zabbix 1.4.
    Gus
  • starstream
    • Jun 2007
    • 13
    I can verify this.
    This is a serious bug!
    ZABBIX Server (daemon) v1.4.1 (29 June 2007) (i have not upated the GUI yet)
    psql (PostgreSQL) 8.2.4
    Suddenly 30 hosts alarmed they had no memory left... and thats because my custom multiplier with 4096 was gone from the memory item
    Cheers!
    • starstream
      • Jun 2007
      • 13
      Maybe it is line
      302: if(0 == get_request("formula",null)) $_REQUEST['multiplier']=0;
      In items.php
      I think it's something like if fomula is null then miltiplier = 0 and by that, disable multiplier. It should be something like if multiplier == null, do not touch it!!
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Thanks for reporting. Fixed in pre 1.4.2. You may download it from http://www.zabbix.com/developers.php.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • starstream
          • Jun 2007
          • 13
          I have installed Pre 1.4.2 (stable) and i can verify that it works!
          Thanks for the fast response and the fix!
          Cheers!
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            Excellent! Thanks for the test.
            Alexei Vladishev
            My Twitter
