I am new to zabbix and today installed 1.4.1 however I am having a few problems getting monitoring working. The first problem is adding a host. I get the following error on the "Configuration" > "Hosts" screen:
maxpower maxpower 192.168.1.90 10050 Template_Linux Monitored Not available ZBX_TCP_READ() failed [Interrupted system call]
So it would seem that the agent cannot connect to the server. The agent and server are the same computer. Here is my zabbix_agentd.conf
# This is config file for zabbix_agentd
# To get more information about ZABBIX, go http://www.zabbix.com
# List of comma delimited IP addresses (or hostnames) of ZABBIX servers.
# No spaces allowed. First entry is used for sending active checks.
# Note that hostnames must resolve hostname->IP address and
# IP address->hostname.
#Server=127.0.0.1
Server=127.0.0.1,192.168.1.90
# Server port for sending active checks
ServerPort=10051
# Unique hostname. Required for active checks.
#Hostname=localhost
Hostname=maxpower
# Listen port. Default is 10050
ListenPort=10050
# IP address to bind agent
# If missing, bind to all available IPs
#ListenIP=127.0.0.1
ListenIP=192.168.1.90
# Number of pre-forked instances of zabbix_agentd.
# Default value is 5
# This parameter must be between 1 and 16
StartAgents=5
# How often refresh list of active checks. 2 minutes by default.
RefreshActiveChecks=120
# Disable active checks. The agent will work in passive mode listening server.
#DisableActive=1
# Enable remote commands for ZABBIX agent. By default remote commands disabled.
#EnableRemoteCommands=1
# Specifies debug level
# 0 - debug is not created
# 1 - critical information
# 2 - error information
# 3 - warnings (default)
# 4 - for debugging (produces lots of information)
DebugLevel=4
# Name of PID file
PidFile=/var/run/zabbix-agent/zabbix_agentd.pid
# Name of log file.
# If not set, syslog will be used
LogFile=/var/log/zabbix-agent/zabbix_agentd.log
# Spend no more than Timeout seconds on processing
# Must be between 1 and 30
Timeout=3
# Format: UserParameter=<key>,<shell command>
# Note that shell command must not return empty string or EOL only
#UserParameter=system.test,who|wc -l
### Set of parameter for monitoring MySQL server (v3.23.42 and later)
### Change -u<username> and add -p<password> if required
#UserParameter=mysql.ping,mysqladmin -uroot -pempire ping|grep alive|wc -l
#UserParameter=mysql.uptime,mysqladmin -uroot -pempire status|cut -f2 -d":"|cut -f1 -d"T"
#UserParameter=mysql.threads,mysqladmin -uroot -pempire status|cut -f3 -d":"|cut -f1 -d"Q"
#UserParameter=mysql.questions,mysqladmin -uroot -pempire status|cut -f4 -d":"|cut -f1 -d"S"
#UserParameter=mysql.slowqueries,mysqladmin -uroot -pempire status|cut -f5 -d":"|cut -f1 -d"O"
#UserParameter=mysql.qps,mysqladmin -uroot -pempirestatus|cut -f9 -d":"
#UserParameter=mysql.version,mysql -V
As you can see I have tried playing around with "localhost" or "hostname". My second problem is no output is getting written to the log file so I am having a hard time debugging things. I am using Ubunutu 7, MySQL, Apache, PHP5.
In short:
Agent not working?
ZBX_TCP_READ() failed [Interrupted system call] when trying to add host
No output to zabbix_agentd.log
Please help
#Server=127.0.0.1
ServerPort=10051
#Hostname=localhost
Hostname=maxpower
ListenPort=10050
#ListenIP=127.0.0.1
StartAgents=5
#DisableActive=1
DebugLevel=4
# Name of PID file
# Name of log file.
Timeout=3
In short:
Agent not working?
Please help
