1.4.1 server HP-UX 11.11 Unresolved symbol: SSLeay (code) from libnetsnmp.sl.10
  • snerge
    • Jun 2007
    Compilation went fine (no warnings/errors) but when I start zabbix_server, here is what I get in the log file (using zabbix_server.conf provided in the source package) :
    5826:20070704:080255 Starting zabbix_server. ZABBIX 1.4.1.
      5826:20070704:080255 **** Enabled features ****
      5826:20070704:080255 SNMP monitoring:       YES
      5826:20070704:080255 WEB monitoring:         NO
      5826:20070704:080255 Jabber notifications:   NO
      5826:20070704:080255 **************************
      5835:20070704:080255 server #6 started [Trapper]
      5837:20070704:080255 server #7 started [Trapper]
      5838:20070704:080255 server #8 started [Trapper]
      5839:20070704:080255 server #9 started [Trapper]
      5840:20070704:080255 server #10 started [Trapper]
      5841:20070704:080255 server #11 started [ICMP pinger]
      5842:20070704:080255 server #12 started [Alerter]
      5843:20070704:080255 server #13 started [Housekeeper]
      5843:20070704:080255 Executing housekeeper
      5846:20070704:080255 server #16 started [Node watcher. Node ID:0]
      5826:20070704:080255 server #0 started [Watchdog]
      5844:20070704:080255 server #14 started [Timer]
      5843:20070704:080255 Deleted 0 records from history and trends
      5843:20070704:080255 No records in table 'config'.
    cat: Cannot open /tmp/zabbix_server_5841.pinger: No such file or directory
    /usr/lib/dld.sl: Unresolved symbol: SSLeay (code)  from /opt/iexpress/net-snmp/lib//libnetsnmp.sl.10
      5826:20070704:080256 One child process died. Exiting ...
    Could it be the way my net-snmp package was built ? (I used the depot from HP's website)
    thanks
    snerge
