Zabbix Version Pre 1.4.2 (stable) Build 4452: Incorrect Trigger Expression
  • Palmertree
    • Sep 2005
    • 746
    With a simple template trigger empression like:
    {Template.Server.Type:icmppingsec.min(300)}=0
    I am getting the following error at the top pannel of the screen when modifing the the trigger:
    # Incorrect trigger expression. [{:icmppingsec.min ... }=0]
    But the change still takes place though. Just a FYI. :-)
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Is it still the case with the very latest code from www.zabbxi.com/developers.php ? I cannot reproduce this.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Palmertree
      • Sep 2005
      • 746
      I will grab the latest code and I wil retest. I will follow backup up.
      • Palmertree
        • Sep 2005
        • 746
        It looks like the problem was from the fact that there old triggers associated to the host from the upgrade from 1.1. I deleted the stale triggers and the error went away. Thanks for the help.
