Zabbix is not use syslog!
  • elliryc
    • Apr 2005
    Hello, i am a french user of zabbix,
    I am using zabbix 1.0 release, because i am in a production envirronement
    first : thanks for your jobs, zabbix is a great monitoring tool.
    second :I have some problems :
    although in the configuration files of zabbix_suckerd and zabbix_agentd, i'm not use the "LogFile" parameter, zabbix is not using syslog.
    In syslog.conf i have write :
    "*.* /var/log/allmessages"
    and i create this files, and reload syslog
    but there's no trace of zabbix in /var/log/allmessages
    of course i can use the logfile but in this way, i can't export the log to another server.
    until i resolv this problem i am using the logfile.
    if anyone know how to resolve my probleme?
    thank you in advance
  • morgolis
    • Oct 2004
    • 33
    i've never used the syslog daemon to log messages from Zabbix, i've always used the log files that Zabbix generates on it's own.
    I'm not sure, but i think you can push messages to the syslog daemon, but unfortunately i don't know how exactly.
    Perhaps someone else can throw some light on this.
    • elliryc
      • Apr 2005
      thank you for your answer
      • elliryc
        • Apr 2005
        Is anyone use syslogd instead of the log file?
        • kevinschmidt
          • Jul 2007
          I have exactly the same problem. Not setting LogFile or setting it to nothing ("LogFile=") deactivates logging, nothing ever reaches syslog. I'm using Zabbix 1.4 and syslog-ng 1.6.11 on Gentoo. Is this a bug or am I doing something wrong?
          Bye,
          Kevin
          • alj
            • Aug 2006
            • 188
            Bye,
            Kevin
            Try this:
            /usr/bin/logger -p local0.err -t zabbix -u /var/log/zabbix-server/zabbix-server.log
            See if zabbix can log into socket instead of log file (probably log rotation should be turned off & logfile deleted).
            • Alexei
              Founder, CEO
              • Sep 2004
              • 5654
              Thanks for reporting this problem.
              Alexei Vladishev
              New York | Tokyo | Riga
              My Twitter
              • gugusg
                • Jun 2008
                • 11
                also the same issue in 1.6. any news about that ?
                • lonerr
                  • Jan 2010
                  Patch
                  --- src/libs/zbxlog/log.c.orig 2010-01-29 15:49:19.000000000 +0300
                  +++ src/libs/zbxlog/log.c 2010-01-29 15:49:33.000000000 +0300
                  @@ -109,7 +109,6 @@
                  #else /* not _WINDOWS */
                  openlog("zabbix_suckerd", LOG_PID, LOG_USER);
                  - setlogmask(LOG_UPTO(LOG_WARNING));
                  #endif /* _WINDOWS */
