Zabbix version: 1.4.1
hardware: PA-RISC chip
OS: HPUX 11i v3
Dear zabbix gurus,
I currently evaluate and test the packages. I have successfully built the agent with AIX 5.3, Solaris10 (Sparc and AMD chip), openSuSE 10.2 (zabbix server on OpenSuSe with IBM pseries hardware), SLES10 (Dell Intel chip, IBM p-series)
I have a problem with building the agent on HPUX server which is on the testing of the platform.
When I ran "configure --enable-agent", it seems to run alright but when I ran "make install" it came out with some errors and exit.
Please tell me what the issue is.
1. ./configure --enable-agent
checking for getopt_long... no
checking for architecture... ok (hpux11.11)
configure: creating ./config.status
config.status: creating Makefile
config.status: creating create/Makefile
config.status: creating create/schema/Makefile
config.status: creating misc/Makefile
config.status: creating src/Makefile
config.status: creating src/libs/Makefile
config.status: creating src/libs/zbxlog/Makefile
config.status: creating src/libs/zbxcrypto/Makefile
config.status: creating src/libs/zbxconf/Makefile
config.status: creating src/libs/zbxdbhigh/Makefile
config.status: creating src/libs/zbxemail/Makefile
config.status: creating src/libs/zbxsysinfo/Makefile
config.status: creating src/libs/zbxsms/Makefile
config.status: creating src/libs/zbxjabber/Makefile
config.status: creating src/libs/zbxcommon/Makefile
config.status: creating src/libs/zbxsysinfo/common/Makefile
config.status: creating src/libs/zbxsysinfo/simple/Makefile
config.status: creating src/libs/zbxsysinfo/linux/Makefile
config.status: creating src/libs/zbxsysinfo/aix/Makefile
config.status: creating src/libs/zbxsysinfo/freebsd/Makefile
config.status: creating src/libs/zbxsysinfo/hpux/Makefile
config.status: creating src/libs/zbxsysinfo/openbsd/Makefile
config.status: creating src/libs/zbxsysinfo/osx/Makefile
config.status: creating src/libs/zbxsysinfo/solaris/Makefile
config.status: creating src/libs/zbxsysinfo/osf/Makefile
config.status: creating src/libs/zbxsysinfo/netbsd/Makefile
config.status: creating src/libs/zbxsysinfo/unknown/Makefile
config.status: creating src/libs/zbxnix/Makefile
config.status: creating src/libs/zbxplugin/Makefile
config.status: creating src/libs/zbxsys/Makefile
config.status: creating src/libs/zbxcomms/Makefile
config.status: creating src/libs/zbxdb/Makefile
config.status: creating src/zabbix_agent/Makefile
config.status: creating src/zabbix_get/Makefile
config.status: creating src/zabbix_sender/Makefile
config.status: creating src/zabbix_server/Makefile
config.status: creating src/zabbix_server/alerter/Makefile
config.status: creating src/zabbix_server/discoverer/Makefile
config.status: creating src/zabbix_server/housekeeper/Makefile
config.status: creating src/zabbix_server/httppoller/Makefile
config.status: creating src/zabbix_server/nodewatcher/Makefile
config.status: creating src/zabbix_server/pinger/Makefile
config.status: creating src/zabbix_server/poller/Makefile
config.status: creating src/zabbix_server/timer/Makefile
config.status: creating src/zabbix_server/trapper/Makefile
config.status: creating src/zabbix_server/utils/Makefile
config.status: creating src/zabbix_server/watchdog/Makefile
config.status: creating upgrades/Makefile
config.status: creating include/config.h
config.status: include/config.h is unchanged
config.status: executing depfiles commands
Configuration:
Detected OS: hpux11.11
Install path: /usr/local
Compilation arch: hpux
Compiler: cc
Compiler flags:
Linker flags:
Libraries: -lm -lnsl
Enable server: no
With database: no
Enable agent: yes
* Now run 'make install' *
* Thank you for using ZABBIX! *
* <http://www.zabbix.com> *
2. # make install
No suffix list.
Making install in create
No suffix list.
Making install in schema
No suffix list.
No suffix list.
No suffix list.
No suffix list.
Making install in misc
No suffix list.
No suffix list.
Making install in src
No suffix list.
Making install in libs
No suffix list.
Making install in zbxcrypto
source='md5.c' object='md5.o' libtool=no \
DEPDIR=.deps depmode=hp /usr/bin/posix/sh ../../../depcomp \
cc -DHAVE_CONFIG_H -I. -I. -I../../../include -c md5.c
(Bundled) cc: "../../../include/common.h", line 157: error 1000: Unexpected symbol: "d".
(Bundled) cc: "../../../include/common.h", line 476: error 1000: Unexpected symbol: "size_t".
(Bundled) cc: "../../../include/common.h", line 476: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 476: error 1573: Type of "size" is undefined due to an illegal declaration.
(Bundled) cc: "../../../include/common.h", line 477: error 1000: Unexpected symbol: "size_t".
(Bundled) cc: "../../../include/common.h", line 477: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 477: error 1573: Type of "size" is undefined due to an illegal declaration.
(Bundled) cc: "../../../include/common.h", line 502: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 519: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 521: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 522: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 523: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 524: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 525: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 526: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 527: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 528: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 529: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 530: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 531: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 532: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 533: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 534: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 535: error 1000: Unexpected symbol: "itemid".
(Bundled) cc: "../../../include/common.h", line 535: error 1000: Unexpected symbol: "time_t".
(Bundled) cc: "../../../include/common.h", line 535: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 535: error 1574: Unknown size for "itemid".
(Bundled) cc: "../../../include/common.h", line 535: error 1573: Type of "now" is undefined due to an illegal declaration.
(Bundled) cc: "../../../include/common.h", line 536: error 1000: Unexpected symbol: "time_t".
(Bundled) cc: "../../../include/common.h", line 536: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 536: error 1573: Type of "now" is undefined due to an illegal declaration.
(Bundled) cc: "../../../include/common.h", line 537: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 540: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 541: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 543: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 544: error 1000: Unexpected symbol: "size_t".
(Bundled) cc: "../../../include/common.h", line 544: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 544: error 1573: Type of "count" is undefined due to an illegal declaration.
(Bundled) cc: "../../../include/common.h", line 545: error 1000: Unexpected symbol: "size_t".
(Bundled) cc: "../../../include/common.h", line 545: error 1000: Unexpected symbol: "va_list".
(Bundled) cc: "../../../include/common.h", line 545: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 545: error 1573: Type of "count" is undefined due to an illegal declaration.
(Bundled) cc: "../../../include/common.h", line 546: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 548: error 1000: Unexpected symbol: "size_t".
(Bundled) cc: "../../../include/common.h", line 548: error 1705: Function prototypes are an ANSI feature.
(Bundled) cc: "../../../include/common.h", line 548: error 1573: Type of "siz" is undefined due to an illegal declaration.
(Bundled) cc: "../../../include/common.h", line 549: error 1000: Unexpected symbol: "zbx_strlcat".
(Bundled) cc: error 2017: Cannot recover from earlier errors, terminating.
*** Error exit code 1
Stop.
OS: HPUX 11i v3
Dear zabbix gurus,
Configuration:
Compiler: cc
Compiler flags:
Linker flags:
Enable server: no
With database: no
Enable agent: yes
2. # make install
No suffix list.
No suffix list.
No suffix list.
No suffix list.
No suffix list.
No suffix list.
No suffix list.
No suffix list.
No suffix list.
No suffix list.
Stop.
