1.4.1: Memory leak.
  • zabbix_es
    • Apr 2007
    • 153
    1.4.1: Memory leak.
    I think that version 1.4.1 continues leaking memory.
    I have to restart zabbix_server each hour to avoid zabbix use all my memory (swap included).
  • zabbix_es
    • Apr 2007
    • 153
    1.4.1: zabbix_server memory leak graph.
    My host has 768 MB of RAM and this is the graph of memory allocation of zabbix_server.
    This is the command I have used:
    >ps -o vsize -C zabbix_server
    • zabbix_es
      • Apr 2007
      • 153
      1.4.1: Right command to watch zabbix_server memory allocation.
      Well, last command is to watch memory allocated by only one of zabbix_servers process.
      Strictly this is the rigth command:
      >ps -C zabbix_server -o vsize |awk -v sum=0 '{sum+=$1} END {print sum}'
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Thanks for this report. May I ask you to try the latest pre 1.4.2?
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • zabbix_es
          • Apr 2007
          • 153
          I have installed version 1.4.2 and memory leaks persists.
          But I read in a thread something about that it could be related to items sent by zabbix_sender and not added to zabbix_server.
          How can I check if that is my trouble?.
          Does server log file show this event?
