Zabbix in win32??
  • piro84
    • Jul 2007
    • 11
    Zabbix in win32??
    Hi all!!
    I can´t install zabbix agent in Windows XP. I had no problems with Debian, but now I´m going crazy. The zabbix_agentd.exe starts to run but it doesn´t work, only say: !!!ATTENTION!!! ZABBIX Agent runned as a console application. !!!ATTENTION!!!
    Thanks!!
    P.D. The zabbix_agentd.conf is in directory C:\
  • mbobkiewicz
    • Aug 2005
    • 36
    Did you do the following?
    C:\zabbix_agentd.exe --install
    C:\zabbix_agentd.exe --start
    It´s the normal way to install Zabbix agent on Win
    Greetings,
    Mike
    • piro84
      • Jul 2007
      • 11
      Thanks!
      Thank you!!
      Now is installed like a service, before only ran.
