Finally was able to install the 1.4.1, but when trying to login into the frontend, the following error pops up and I found no way to get around this:
* Error in query [select u.* from users u where u.alias='guest' and (u.userid div 100000000000000)=0] [You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'div 100000000000000)=0' at line 1]
* mysql_fetch_array(): supplied argument is not a valid MySQL result resource[/srv/www/htdocs/zabbix/include/db.inc.php:411]
* Error in query [select u.userid,u.alias,u.name,u.surname,u.url,u.refresh from users u where u.alias='Admin' and u.passwd='a559c567f254cd3792353d8a5fd1f019' and (u.userid div 100000000000000)=0] [You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'div 100000000000000)=0' at line 1]
* Error in query [insert into auditlog (auditid,userid,clock,action,resourcetype,details) values (3,0,1184673312,3,0,'Login failed [Admin]')] [Duplicate entry '3' for key 1]
A select from the users table:
mysql> select * from users;
| userid | alias | name | surname | passwd | url | autologout | lang | refresh | type |
| 1 | Admin | Zabbix | Administrator | a559c567f254cd3792353d8a5fd1f019 | | 900 | en_gb | 30 | 3 |
| 2 | guest | Default | User | d41d8cd98f00b204e9800998ecf8427e | | 900 | en_gb | 30 | 1 |
| 3 | helpdesk | XXXXXX | helpdesk | eb4985990d10e3e2f5e3f30359ed0ccb | screens.php | 3600 | en_gb | 60 | 1 |
| 4 | XXXX | XXXXXXXXX | XXXXX | 051f74dbdc2db120b197dff11d1b682d | | 900 | en_gb | 30 | 1 |
| 5 | it | XXXXXX | it | 0d149b90e7394297301c90191ae775f0 | tr_status.php | 900 | en_gb | 30 | 1 |
| 6 | readonly | readonly | readonly | b3e3f521afc37ca6622964da4466b07c | http://XXXXXXXXXXXXXXXXXXXX/zabbix/tr_status.php | 900 | en_gb | 30 | 1 |
6 rows in set (0.00 sec)
(put some XX instead of names)
Please help. I'm stuck without monitoring at this stage.
