Windows Zabbix Agent 1.1.6 big problem
  • Ismael Medina
    • Mar 2007
    • 15
    Hi, I has been experienced a problem with this Zabbix agent.
    Actually I have almost 130 Windows servers monitored with Zabbix, some with 64 bits processors and until now i did't have problems, but...
    I has been triyin to install the zabbix agent on a server IBM 3950 with 8 processors, but the Zabbix agent simply hangs.
    Debugging the agent i found that in main.cpp are a function defined like
    // Initialization routine
    BOOL Initialize(void)
    Inside there are a line that is the last executed.
    // Start TCP/IP listener and collector threads
    _beginthread(CollectorThread,0,NULL);
    WaitForSingleObject(eventCollectorStarted,INFINITE ); // Allow collector thread to initialize
    Why, someone knows how to fix this????
    Thanks in advance.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I have no idea. May I ask you to run the latest agent from 1.4.1 (or pre 1.4.2). It supports statistics of up-to 16 CPUs.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
