DB-Patch from 1.4 to 1.4.1 for Application linkage
  • just2blue4u
    • Apr 2006
    • 347
    Hi there!
    Thanks everyone for v1.4.1!!!
    In the release notes it says "fixed linkage of applications in 1.1.x migration scripts".
    So i made an update from Zabbix 1.4 to 1.4.1.
    Zabbix seems to work quite good, but still my applications aren't shown.
    I think this bug is fixed in the DB update patch. I am missing an DB update file from 1.4 to 1.4.1. There is only that one for 1.1.x Versions.
    Yes, i know that the DB doesn't have to be modified, but as far as i know, the application problem is in the DB.
    Will there be made an DB update Script for 1.4 to 1.4.1, or can someone tell me how i can solve the Problem by myself?
    Thanks for any piece of information!
    Heiner
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
