howto get aggregate checks working
  • Saftnase
    • Jul 2006
    • 30
    i have define a group called Terminalserver and want to monitor the number of processes in that group. so i tried to use a key called
    grpsum('Terminalserver',proc.num[]','last','0')
    valuetype is float
    all i get is the message: Incorrect key format 'key_name[param1,param2,...]'
    i also tried to use the example key from the manual (hopeing i made a syntax mistake) grpsum('Zabbix Servers','vfs.fs.size[/,total]','last','0')
    but the same here with only one host in the group.
    whats wrong ?
    using zabbix 1.4.1 on fedora core 6
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Thanks for reporting this!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
