I was monitoring more than 70 nodes using nagios now i have monitoring it using zabbix 1.4.1 i have few problems/suggetions.
zabbix frontend look is very nice however most important feature zabbix missing is repeated alerts that nagios can generating at predefined intervals.
to tackle i have set diffrent triggers for monitoring same item but i am facing one problem.
I am trying to monitor CPU load on firewall i have set diffrent triggers with various saverity levels as
load >60- warning
load > 70 - average
load > 80 -High
load > 90 - Disaster
however when load goes beyond 70 or 80 it generates 2-3 alerts for each severity
i want if load goes beyond 80 alerts for high only should get generate.
also alerts generating immediately i want to generate alerts when load goes beyound 70 zabbix should retry check after every 30 secs for 5 times if still load not recovers then alert should be generated.
can anybody tell me how i can do this.
is zabbix is planning to create repeated alerts in next release.
load >60- warning
load > 70 - average
load > 80 -High
