w32 Agent with Win XP SP2
  • 753713
    • Apr 2006
    • 137
    i have this error with Zabbix w32 Agent 1.4.1 on Windows XP:
    C:\Daten\win32>zabbix_agentd.exe -i
    zabbix_agentd.exe [1596]: ZABBIX Agent service created successfully.
    zabbix_agentd.exe [1596]: Event source "ZABBIX Agent" installed successfully.
    C:\Daten\win32>zabbix_agentd.exe -s
    zabbix_agentd.exe [2912]: ERROR: Cannot start service named 'ZABBIX Agent' [Der
    Dienst antwortete nicht rechtzeitig auf die Start- oder Steuerungsanforderung.
    Christian
    ______________________________
    Version : 2.0.x
    Server OS: Ubuntu 12.04
    Zabbix Servers: 12
    Monitored Windows Server: ~ 1000
  • swaterhouse
    • Apr 2006
    • 268
    Is it possible to translate the german to english?
    • 753713
      • Apr 2006
      • 137
      sorry, here in englisch:
      zabbix_agentd.exe [2912]: ERROR: Cannot start service named 'ZABBIX Agent' [The service did not answer punctual to the starting or control requirement]
      Christian
      Version : 2.0.x
      Zabbix Servers: 12
      • swaterhouse
        • Apr 2006
        • 268
        Can you post the output of the log file?
        • 753713
          • Apr 2006
          • 137
          the logfile is empty
          Christian
          Version : 2.0.x
          Zabbix Servers: 12
          • NOB
            • Mar 2007
            • 469
            Christian
            This should really read (not translated by a machine but manually by me):
            [The service did not respond in time to the start or control request]
            But, nonetheless, the right english translation doesn 't help either.
            Check the location of the image file in the registry.
            It might be wrong. Check for the location of the Install_Dir, too.
            The config file zabbix_agentd.conf must reside in the same directory.
            HTH,
            Norbert.
            • wurm
              • Jun 2007
              • 12
              Actually, from my experience with the 1.4.1 windows exe, unless you specify the location of the config file, whether when starting, stopping or installing, it looks at C:\. But it would have given an error message that it couldn't find the conf file if that was the case, and it didn't... could you please post your conf file, Christian?
              Thanks,
              Wurm
              • 753713
                • Apr 2006
                • 137
                here is my configfile:
                Server=192.168.0.11
                LogFile=c:\zabbix\zabbix_agentd.log
                the zabbix_agentd.exe is in folder c:\zabbix
                install zabbix:
                zabbix_agentd.exe -i -c c:\zabbix\zabbix_agentd.conf
                uninstall zabbix:
                zabbix_agentd.exe -d -c c:\zabbix\zabbix_agentd.conf
                start zabbix:
                zabbix_agentd.exe -s -c c:\zabbix\zabbix_agentd.conf
                stop zabbix:
                zabbix_agentd.exe -x -c c:\zabbix\zabbix_agentd.conf
                Christian
                Version : 2.0.x
                Zabbix Servers: 12
                • wurm
                  • Jun 2007
                  • 12
                  Couple of thoughts:
                  Use task manager and make sure there are no instances of zabbix_agentd.exe running or hung, etc.
                  Wow. That's a pretty minimal conf file. I'm not sure what is required to be there, but if you are not disabling active checks, then I believe you need to put the hostname of your monitored machine in there.
                  Hostname=myhostname
                  If you want to disable active checks, then add this line:
                  DisableActive=1
                  Also, my conf file has a Timeout listed, but does not list a default, so maybe it is required? Not sure, but you can add something like the following.
                  # Spend no more than Timeout seconds on processing
                  # Must be between 1 and 30
                  Timeout=3
                  Does anything get logged if you add the following line to your conf file and try to start it?
                  DebugLevel=5
                  Wurm
                  • wurm
                    • Jun 2007
                    • 12
                    Hmmm... broke open the 1.4 manual again, and I may have led you astray on a couple of those conf file parameters... I don't see any mention of Timeout, DisableActive or Hostname in the windows agent section. But maybe setting the DebugLevel will help reveal something.
                    Wurm
                    • 753713
                      • Apr 2006
                      • 137
                      my problem is McAfee Virus Scanner.
                      Christian
                      Version : 2.0.x
                      Zabbix Servers: 12
                      • wurm
                        • Jun 2007
                        • 12
                        Glad to hear you got it figured out.
                        Auf Wiedersehen,
                        Wurm
