1.4.1 Trigger expression NOT working !!
  • BusteR81
    • Apr 2007
    • 150
    Hello, is there a bug with '&' expression or is there a bug in the .abschange(0) function ??
    Trigger:
    (Host02:cpmActiveDS0s.abschange(0)>10)&
    (Host02:cpmActiveDS0s.last(0)<Host02:cpmActiveDS0s.prev(0))
    Email Alert:
    Sudden Drop in Total Active calls on Host02 on 2007.07.26 at 10:53:13 :
    Current value = 6
    Previous value = 7
    Q: Why is the Trigger = TRUE and sent the above Email alert?
  • BusteR81
    • Apr 2007
    • 150
    time function not available in 1.4.1 ?
    tried using the useful .time(0) funtion but server told mi "time(0) not a valid function" so if such feature has not been added to 1.4.1, perhaps do an update on Zabbix Manual document in case anyone trys it and hit deadend.
    Cheers
    I do tink more in-depth tests should be done on triggers expressions especially complex ones with '&' and '|' etc (push trigger expression to limit) otherwise Zabbix is a Powerful tool.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Originally posted by BusteR81
      Trigger:
      Please could you post exact (with all {}) trigger expression? Thank you.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • BusteR81
        • Apr 2007
        • 150
        with {}
        Trigger:
        ({Host02:cpmActiveDS0s.abschange(0)}>10)&
        ({Host02:cpmActiveDS0s.last(0)}<{Host02:cpmActiveD S0s.prev(0)})
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          I cannot reproduce this with the latest pre 1.4.2. How the item cpmActiveDS0s is configured? Does it use delta?
          Alexei Vladishev
          My Twitter
          • BusteR81
            • Apr 2007
            • 150
            juz a thought... no alarms
            cpmActiveDS0s returns total active calls from a snmp router (VoIP)
            anyway i got it solved by working around and using simpler trigger expression, however i still have my doubts over complicated triggers expressions.
            Eg...of how i feel over stability of trigger expression:
            1+X = oK
            (1+X)x2 = oK
            ((1+X)x2) + 3/X = still oK i guess
            ( ((1+X)x2) + (3/X) < 4 ) & ( ((5+2)x2) < ((6-2)x2) ) = ??? (can Zabbix do this maths equation with 100% confidence)
            it is not that i dun trust Zabbix triggers but when maths get complicated, things might just go 'weird' Do u developers test with such complicated triggers expressions. oh well...
            Cheers
            just telling how i feel over 1.4.1 Trigger expression
            • Alexei
              Founder, CEO
              • Sep 2004
              • 5654
              1+X = oK
              (1+X)x2 = oK
              If you look at the server.c you could see that evaluation of trigger expressions is regression tested. Keep in mind operator precedence and you will be fine
              Alexei Vladishev
              My Twitter
