Zabbix outgoing ports
  • oliverm
    • May 2006
    • 155
    Does anyone know what ports zabbix server makes its outbound connections from ? I know it connects to the agent on 10050, and the agent to the server on 10051, but i need to know what port the connections FROM the server to the agent come from.
    Olly
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Any random port higher than 1024.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • oliverm
      • May 2006
      • 155
      Is there anyway to force it to connect from a defined range of ports so that i can include these in our outbound firewall ports ?
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        It is not supported by ZABBIX. Perhaps this can be configured somehow on OS level, I don't know...
        Alexei Vladishev
        My Twitter
        • sterno
          • Jan 2006
          • 24
          If your server is on Linux you may be able to use an iptables SNAT rule to rewrite the outbound connections to a specified range of source ports. You can probably do it with ipfilter or pf on other platforms, but off the top of my head I don't remember the syntax.
          The proper place for this to be addressed is at the application level. However, I don't think it's very common to filter on the source port - usually the only source port filtering is based on ports above/below 1024 or inside/outside the ephemeral range. I have used very few applications that allow you to specify source ports.
