Hi there,
can anybody tell me why there is no choice for e.g. CPU as Application in the template configuration ? I can only add an application if i add the item to a host but then i can't copy it to a template.
Also there is a bug when you want to save the item because often you are working on a template item but it wants to save it to a host item and says duplicate key and you can't delete the host item.
