Hi all,
I don't know what I have to do anymore, because I've tried everything the forum has concerning this problem!
See below my config file:
Below follows the zabbix_agentd test result:
It's drives me CRAZY!!!
Can anybody help me?
# List of comma delimited IP addresses of ZABBIX servers. No spaces allowed.
# First IP is used for sending active checks.
Server=172.31.10.137
# Server port for sending active checks
#ServerPort=10051
# Unique hostname. Required for active checks.
Hostname=localhost
# Listen port. Default is 10050
#ListenPort=10050
# IP address to bind agent
# If missing, bind to all available IPs
#ListenIP=127.0.0.1
# Number of pre-forked instances of horus_agentd.
# Default value is 5
# This parameter must be between 1 and 16
StartAgents=5
# How often refresh list of active checks. 2 minutes by default.
#RefreshActiveChecks=120
# Specifies debug level
# 0 - debug is not created
# 1 - critical information
# 2 - error information
# 3 - warnings (default)
# 4 - for debugging (produces lots of information)
DebugLevel=3
# Name of PID file
PidFile=c:\zabbix\zabbix_agentd.pid
# Name of log file.
# If not set, syslog will be used
LogFile=c:\zabbix\/zabbix_agentd.log
# Spend no more than Timeout seconds on processing
# Must be between 1 and 30
Timeout=3
##### Experimental options. Use with care ! #####
# Get rid of sockets in TIME_WAIT state
# This will set socket option SO_LINGER
# NoTimeWait=1
##### End of experimental options
# Format: UserParameter=<key>,<shell command>
# Note that shell command must not return empty string or EOL only
#UserParameter=system[test],who|wc -l
### Set of parameter for monitoring MySQL server (v3.23.42 and later)
### Change -u<username> and add -p<password> if required
#UserParameter=mysql[ping],mysqladmin -uroot ping|grep alive|wc -l
#UserParameter=mysql[uptime],mysqladmin -uroot status|cut -f2 -d":"|cut -f1 -d"T"
#UserParameter=mysql[threads],mysqladmin -uroot status|cut -f3 -d":"|cut -f1 -d"Q"
#UserParameter=mysql[questions],mysqladmin -uroot status|cut -f4 -d":"|cut -f1 -d"S"
#UserParameter=mysql[slowqueries],mysqladmin -uroot status|cut -f5 -d":"|cut -f1 -d"O"
#UserParameter=mysql[qps],mysqladmin -uroot status|cut -f9 -d":"
#UserParameter=version[mysql],mysql -V
PerfCounter=NetIn,"\Interface de rede(3Com EtherLink XL 10_100 PCI For Complete PC Management NIC [3C905C-TX] - Miniporta do agendador de pacotes)\Bytes recebidos/s",60
PerfCounter=NetOut,"\Interface de rede(3Com EtherLink XL 10_100 PCI For Complete PC Management NIC [3C905C-TX] - Miniporta do agendador de pacotes)\Bytes enviados/s",60
#ServerPort=10051
Hostname=localhost
#ListenPort=10050
#ListenIP=127.0.0.1
StartAgents=5
DebugLevel=3
# Name of PID file
# Name of log file.
Timeout=3
# NoTimeWait=1
C:\zabbix>zabbix_agentd.exe -c c:\zabbix\zabbix_agentd.conf -t NetIn,"\Interface de rede(3Com EtherLink XL 10_100 PCI For Complete PC Management NIC [3C905C-TX] - Miniporta do agendador de pacotes)\By
tes recebidos/s",60
NetIn,\Interface de rede(3Com EtherLink XL 10_100 PCI For Complete PC Management NIC [m|ZBX_NOTSUPPORTED]
tes recebidos/s",60
