Plain Text line wrapping.
  • traq911
    • May 2005
    • 17
    I've been gathering 'top' data and storing it as plain text. I've built a screen with a plain text cell that looked like this:
    In Zabbix 1.4.x it now looks like this:
    Is there any reason "plain text" parsing does not break on carriage returns in screen tables anymore?
  • rolandsym
    • Jul 2007
    • 76
    trying with windows
    hi,
    I'm trying to do the same with a vbs script in windows but I get truncated by 255 characters. I wanted to do what you had setup on the screen pane with generated command info.
    Rolandsym
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      It is fixed in pre 1.4.2!
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • traq911
        • May 2005
        • 17
        Looks like the problem is back in 1.6.0
        I just upgraded to 1.6 and am now getting a single line of text again. It a little different this time though. The end of lines are actually marked with the html tag <br>.
        • Aly
          ZABBIX developer
          • May 2007
          • 1126
          I you sure that string it self does not contain html tags?
          Zabbix | ex GUI developer
          • traq911
            • May 2005
            • 17
            Using Unix top command
            The string I'm collecting is generated from the Unix top command. I don't think it's generating HTML tags
            • rwa
              • Oct 2008
              • 9
              I ran into this same issue, also from unix output (ps). The basic flow of data getting onto a screen is:
              screen.php -> screen.inc.php
              on line 373 of screen.inc.php a string value like this is formatted with:
              $value = nl2br(nbsp(htmlspecialchars($row["value"])));
              which is fine b/c the nl2br is added outside of the htmlspecialchars function, so the <br /> that nl2br inserts for a newline is not encoded by htmlspecialchars.
              The flow is then:
              line 384 of screen.inc.php -> AddRow function of the CTable class in ctable.inc.php -> PrepareRow function of the CTable class in ctable.inc.php -> AddItem function of the CRow class in ctable.inc.php -> AddItem function of CTag class in ctag.inc.php
              on line 107 of ctag.inc.php you have
              array_push($this->items,str_replace(array('<','>','"'),array('&lt;','&gt;','&quot;'),$value));
              and it is this which then effectively html encodes the <br /> tags added above and causes the text to render the multiple lines as one long line.
              I don't know in what situations this is actually useful (so text would get here w/o passing through the first encoding step), so I don't want to just remove it (though that works for this particular case). What I changed it to was:
              array_push($this->items,str_replace('&lt;br /&gt;', '<br />', str_replace(array('<','>','"'),array('&lt;','&gt;','&quot;'),$value)));
              which just adds an additional replace searching for encoded <br /> tags and reverts them to unencoded ones. This would still break in a situation where:
              1) your text has <br /> tags in it
              2) it does not pass through the first encoding step that this path does
              In that case line 107 would encode them but my change would unencode them. For us this shouldn't be an issue as no data we capture is html, but someone that really knows what they are doing could probably fix this better.
              Thanks.
              • radamand
                • Aug 2008
                • 89
                I am having the same problem; I have an item that queries several lines of text out of a MySQL database and stores it as plain text, when I insert this into a screen it has a bunch of "<br />" inserted in it, and the screen shows each poll of data on a single line, where it should be showing several lines of data just from the last poll.
                wrong:
                Host your images online with an easy to use image uploader, albums, photo hosting, sharing, dynamic image resizing on web and mobile.
                what it should look like: (image is taken from Latest Data -> History)
                • Aly
                  ZABBIX developer
                  • May 2007
                  • 1126
                  Hmm no one sad that this problem is in the Screens page...
                  P.S. well changeing this line:
                  PHP Code:
                  to this:
                  PHP Code:
                  $value = zbx_nl2br(nbsp(htmlspecialchars($row["value"])));
                  Should help.
                  • radamand
                    • Aug 2008
                    • 89
                    not to pick nits, but, the original poster did;
                    "Is there any reason "plain text" parsing does not break on carriage returns in screen tables anymore?"
                    but, thanks for the fix, works great!
                    and thanks for a great tool!
                    • radamand
                      • Aug 2008
                      • 89
                      ack, problem with that fix...
                      Screen shot
                      • Aly
                        ZABBIX developer
                        • May 2007
                        • 1126
                        Screen shot
                        I see...
                        PHP Code:
                                            $value = nbsp(htmlspecialchars($row['value']));
                        $value = zbx_nl2br($value);
                        • radamand
                          • Aug 2008
                          • 89
                          That fixed it, thanks again!
