Graph display acting funny
  • TeeKay3001
    • Apr 2006
    • 22
    Ever since updating (I actually did a total re-install) from an earlier (about 1.0/1.1) version I have been having the graph display being there one moment and the next moment the graph is empty. I check the "Latest data" and it's all there. It then starts displaying the data asif it has just started collecting the data.
    I'm running on Redhat EL4 and version 1.4.1 of Zabbix.
    This is not just a gap in the graph as reported by others, but a display that was there one moment and with the next refresh its blank and then starts all over again.
    Let me know what data you need from me if any...
  • TeeKay3001
    • Apr 2006
    • 22
    I seem to have sorted the problem out by turning off housekeeping.
    I thought this problem had been solved in 1.4.1??
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      It is solved in pre 1.4.2 which does not use long transactions for housekeeper.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
