Distributed Monitoring soft of works?
  • rolandsym
    • Jul 2007
    • 76
    I finally was able to setup distributed monitoring with the latest build as of Monday. The servers are passing most of the data between them for the past day. It doesn't send the history_txt data across. Also, it only does current, no back dating.
    The issue I'm having is overview.php and latest.php do not show latest values. If you goto graphs or history you see the data. I've checked the database and it is all there(minus history_txt). So, is this a php problem? What do I need to look at to maybe fix it in php?
    Any help mucho appreciated.
    Rolandsym
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Currently ZABBIX does not send data from history_text across the nodes.
    Also, operational information which changes frequently, like item's last check timestamp and latest value, is not synchronized as well.
    This will be addressed in the future releases, perhaps even in 1.4.2.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
