freebsd 4.7 agent compilation issue
  • ghislain
    • Jun 2005
    • 160
    Hello there,
    i try to compile agent fro freebsd 4.7 (version 1.4.2) but i fail here:
    version: 4.7-RELEASE-p28 FreeBSD 4.7-RELEASE-p28
    ./configure --enable-agent --disable-server --without-jabber --without-ucd-snmp --without-net-snmp --without-pgsql --without-mysql
      core1:/root/zabbix-1.4.2%(root)> make
    Making all in create
    Making all in schema
    Making all in misc
    Making all in src
    Making all in libs
    Making all in zbxcrypto
    Making all in zbxcommon
    Making all in zbxlog
    source='log.c' object='log.o' libtool=no  DEPDIR=.deps depmode=gcc /usr/local/bin/bash ../../../depcomp  gcc -DHAVE_CONFIG_H -I. -I. -I../../../include      -g -O2 -c log.c
    log.c: In function `zabbix_open_log':
    log.c:121: syntax error before `;'
    log.c:127: syntax error before `;'
    *** Error code 1
    Stop in /root/zabbix-1.4.2/src/libs/zbxlog.
    *** Error code 1
    Stop in /root/zabbix-1.4.2/src/libs.
    *** Error code 1
    Stop in /root/zabbix-1.4.2/src.
    *** Error code 1
    Stop in /root/zabbix-1.4.2.
    Any ideas ?
    regards,
    Ghslain.
    Regards,
    Ghislain.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It seems your GCC is broken, really. Try to use a different version of the compiler.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • ghislain
      • Jun 2005
      • 160
      the 1.4.1 works like a charm but i cannot compile the 1.4.2. Does the agents have been changed a lot between the two versions on unix ?
      regards,
      Ghislain.
      Regards,
      Ghislain.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        We cannot help you if you won't provide more details...
        Alexei Vladishev
        My Twitter
        • Eugene
          • Feb 2006
          • 57
          I hope, this patch can solve you problem.
          • ghislain
            • Jun 2005
            • 160
            i tried it but i still have the same issue:
            cd ../../.. && make  am--refresh
            *** Error code 1
            1 error
            Regards,
            Ghislain.
            • Eugene
              • Feb 2006
              • 57
              Keep in mind, what you must recreate configuration script and reconfigure sources.
              After software configuration, line with "HAVE___VA_ARGS__" must be comented in "include/config.h"
              P.S.
              to recreate configuration script, type:
              > aclocal -I m4
              > autoconf
              > autoheader
              > automake
              • ghislain
                • Jun 2005
                • 160
                   102  15:25   rm -Rf zabbix-1.4.2
                   103  15:25   tar -zxf zabbix-1.4.2.tar.gz
                   104  15:25   cd zabbix-1.4.2
                   105  15:26   patch < ../patch.txt
                   107  15:26   aclocal14 -I m4
                   108  15:26   autoconf
                   109  15:26   autoconf259
                   112  15:26   autoheader259
                   113  15:26   automake14
                result:
                Hmm...  Looks like a unified diff to me...
                The text leading up to this was:
                |Index: configure.in
                |--- configure.in       (revision 4639)
                |+++ configure.in       (working copy)
                Patching file configure.in using Plan A...
                Hunk #1 succeeded at 435.
                done
                (aqadmin)> automake14
                automake: configure.in: required file `./mkinstalldirs' not found
                automake: src/libs/zbxsysinfo/Makefile.am: not supported: source file `@ARCH@/@[email protected]' is in subdirectory
                src/zabbix_server/Makefile.am:29: invalid unused variable name: `JABBER_LDADD'
                (aqadmin)> ./configure --enable-agent --disable-server --enable-static
                ...snip...
                checking for atoll... no
                checking for getopt_long... no
                ./configure: line 7792: syntax error near unexpected token `IKSEMEL,iksemel,'
                ./configure: line 7792: `               PKG_CHECK_MODULES(IKSEMEL,iksemel,'
                (aqadmin)> grep 'HAVE___VA_ARGS__' include/config.h
                /* #define HAVE___VA_ARGS__ 1 */
                i am not a dev so i done the way i was thinking it would have to be done to work. The 1.4.1 works but even with the patch the 1.4.2 does not compile.
                Regards,
                Ghislain.
                • Eugene
                  • Feb 2006
                  • 57
                  you can use this script.
                  Usage:
                  a) place script 'recreate', 'zabbix-1.4.2.tar.gz' and vaargs.patch in to the one folder
                  b) run 'recreate' script and you must see 'SUCCEED' finaly message
                  c) go to the 'zabbix-1.4.2', configure and compile
                  • ghislain
                    • Jun 2005
                    • 160
                    sh ./recreat core1:/usr/local/.aqadmin/home%(root)> sh ./recreate.sh
                    1. Cleaning...
                    2. Untaring...
                    3. Patching...
                    |Index: configure.in
                    done
                    4. Pre-making...
                    a) aclocal14
                    b) autoconf259
                    c) autoheader259
                    d) automake14
                    automake: configure.in: installing `./mkinstalldirs'
                    FAIL
                    it fails
                    ps: i had to change the binary name as they are nammed this way on my freebsd box.
                    Regards,
                    Ghislain.
                    • Eugene
                      • Feb 2006
                      • 57
                      it fails
                      oh no... you'e have old version of automake...
                      So, in this case, you can try this path directly for configuration script.
                      P.S. this is a temporaly solution
                      • ghislain
                        • Jun 2005
                        • 160
                        it still does not compile
                         (root)> make
                        Making all in misc
                        Making all in src
                        Making all in libs
                        *** Error code 1
                        Stop in /usr/local/.aqadmin/home/zabbix-1.4.2/src/libs/zbxlog.
                        *** Error code 1
                        note i had not the same error as the AIX user. so perhaps this is not the same issue.
                        Regards,
                        Ghislain.
                        • bee
                          • Jun 2007
                          • 133
                          P.S.
                          > aclocal -I m4
                          > autoconf
                          > autoheader
                          > automake
                          Hi Eugene,
                          Mine stop on:
                          a) aclocal
                          aclocal: not found
                          FAIL
                          Please advice, seem my box doesn't have aclocal binary. I don't have idea what aclocal is. And if you don't mind hope you can explain it to me and describe how to get it?
                          Sorry if this question is not more like unix essential, but i'll appreciate it.
                          Thanks,
                          BEE
                          • bee
                            • Jun 2007
                            • 133
                            Hi Alexei,
                            What is your recomendation of GCC version for better zabbix compilation?
                            Please advice.
                            Thanks,
                            BEE
                            • Alexei
                              Founder, CEO
                              • Sep 2004
                              • 5654
                              #15
                              I made a workaround yesterday. Please try to use the latest 1.4.x code from www.zabbix.com/developers.php.
                              Alexei Vladishev
                              My Twitter
