I have problems to compile zabbix on AIX 5.2 (using Visual Age Compiler).
Any help available? Thanks in advance.
This is the result of the compilation:
Configuration:
Detected OS: aix5.2.0.0
Install path: /opt/zabbix
Compilation arch: aix
Compiler: cc -qlanglvl=extc89
Compiler flags: -g
Enable server: no
Enable agent: yes
Linker flags: -Wl,-bbigtoc
Libraries: -lm
LDAP support: no
* Now run 'make install' *
* Thank you for using ZABBIX! *
* <http://www.zabbix.com> *
Making all in create
Making all in schema
Target "all" is up to date.
Target "all-am" is up to date.
Making all in misc
Making all in src
Making all in libs
Making all in zbxcrypto
source='md5.c' object='md5.o' libtool=no DEPDIR=.deps depmode=aix /bin/sh ../../../depcomp cc -qlanglvl=extc89 -DHAVE_CONFIG_H -I. -I. -I../../../include -g -c md5.c
source='base64.c' object='base64.o' libtool=no DEPDIR=.deps depmode=aix /bin/sh ../../../depcomp cc -qlanglvl=extc89 -DHAVE_CONFIG_H -I. -I. -I../../../include -g -c base64.c
rm -f libzbxcrypto.a
ar cru libzbxcrypto.a md5.o base64.o
ranlib libzbxcrypto.a
Making all in zbxcommon
source='misc.c' object='misc.o' libtool=no DEPDIR=.deps depmode=aix /bin/sh ../../../depcomp cc -qlanglvl=extc89 -DHAVE_CONFIG_H -I. -I. -I../../../include -g -c misc.c
source='regexp.c' object='regexp.o' libtool=no DEPDIR=.deps depmode=aix /bin/sh ../../../depcomp cc -qlanglvl=extc89 -DHAVE_CONFIG_H -I. -I. -I../../../include -g -c regexp.c
source='xml.c' object='xml.o' libtool=no DEPDIR=.deps depmode=aix /bin/sh ../../../depcomp cc -qlanglvl=extc89 -DHAVE_CONFIG_H -I. -I. -I../../../include -g -c xml.c
source='comms.c' object='comms.o' libtool=no DEPDIR=.deps depmode=aix /bin/sh ../../../depcomp cc -qlanglvl=extc89 -DHAVE_CONFIG_H -I. -I. -I../../../include -g -c comms.c
source='str.c' object='str.o' libtool=no DEPDIR=.deps depmode=aix /bin/sh ../../../depcomp cc -qlanglvl=extc89 -DHAVE_CONFIG_H -I. -I. -I../../../include -g -c str.c
source='zbxgetopt.c' object='zbxgetopt.o' libtool=no DEPDIR=.deps depmode=aix /bin/sh ../../../depcomp cc -qlanglvl=extc89 -DHAVE_CONFIG_H -I. -I. -I../../../include -g -c zbxgetopt.c
source='alias.c' object='alias.o' libtool=no DEPDIR=.deps depmode=aix /bin/sh ../../../depcomp cc -qlanglvl=extc89 -DHAVE_CONFIG_H -I. -I. -I../../../include -g -c alias.c
rm -f libzbxcommon.a
ar cru libzbxcommon.a misc.o regexp.o xml.o comms.o str.o zbxgetopt.o alias.o
ranlib libzbxcommon.a
Making all in zbxlog
source='log.c' object='log.o' libtool=no DEPDIR=.deps depmode=aix /bin/sh ../../../depcomp cc -qlanglvl=extc89 -DHAVE_CONFIG_H -I. -I. -I../../../include -g -c log.c
"log.c", line 121.63: 1506-041 (E) The invocation of macro zbx_error contains fewer arguments than required by the macro definition.
"log.c", line 121.25: 1506-046 (S) Syntax error.
"log.c", line 121.25: 1506-098 (E) Missing argument(s).
"log.c", line 127.72: 1506-041 (E) The invocation of macro zbx_error contains fewer arguments than required by the macro definition.
"log.c", line 127.25: 1506-046 (S) Syntax error.
"log.c", line 127.25: 1506-098 (E) Missing argument(s).
make: 1254-004 The error code from the last command is 1.
Stop.
Stop.
Stop.
Stop.
Configuration:
Compiler flags: -g
Enable server: no
Enable agent: yes
Libraries: -lm
LDAP support: no
Making all in misc
Making all in src
Making all in libs
Stop.
Stop.
Stop.
Stop.
