Bug in triggerscreen on 1.4.2
  • cybaspace
    • Jul 2005
    • 43
    There seems to be a bug in version 1.4.2 of the zabbix frontend.
    When you select 'Show Only true', the triggerscreen also shows the 'false' triggers. In version 1.4.1 it works okay and only displays the 'true' triggers.
    Cheers!
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    This is a feature! It will show FALSE and UNKNOWN trigger only when they changed their status within 30 minutes by default.
    I think this is very nice improvement of the screen.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • cybaspace
      • Jul 2005
      • 43
      Okay, I didn't knew that. Is there a way to use it the way it was in 1.4.1? We only want to show triggers that are 'true'.
      It looks kinda confusing if you select 'Only show True' that also the 'old true triggers' are displayed as 'false'.
      Cheers!
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Do you see these triggers blinking?
        Anyway, you may change TRIGGER_BLINK_PERIOD to 0 in defines.inc.php for 1.4.1-like functionality.
        Alexei Vladishev
        My Twitter
        • cybaspace
          • Jul 2005
          • 43
          Oh, now I see what that new feature is about! I opened the triggerscreen in Firefox and the triggers are indeed blinking and that is a very nice new feature! Normally we use IE and the triggers don't blink in there.
          Well, we have to move over to firefox then ;-)
          Thanks for the help!
          • ghislain
            • Jun 2005
            • 160
            i think this is an improvement but when you retsrat zabbix it would print them all again. SO this could be better if it does not triggers this features after a restart at the first check perhaps ?
            thanks for the tip it does revert to 'normal' (pre 1.4.2) behavior
            Regards,
            Ghislain.
            • Alexei
              Founder, CEO
              • Sep 2004
              • 5654
              It was improved to work in IE6 as well.
              Alexei Vladishev
              My Twitter
