Can't access Graphs configuration after migrating from 1.4.1 to 1.4.2
  • dsipe
    • Oct 2006
    • 184
    I've got the following error when clicking on the link Configuration->Graphs
    * Error in query [select distinct g.* from graphs g left join graphs_items gi on g.graphid=gi.graphid left join items i on gi.itemid=i.itemid while (g.graphid div 100000000000000) in (0) and ( i.hostid not in (-1) OR i.hostid is NULL ) order by g.name, g.graphid] [You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'while (g.graphid div 100000000000000) in (0) and ( i.hostid not in (-1) OR i.' at line 1]
    * mysql_fetch_array(): supplied argument is not a valid MySQL result resource[/srv/www/htdocs/zabbix/include/db.inc.php:411]
    What's wrong ??
    nb: i don't make any change to the database schema when migrating to 1.4.2, hoping that nothing has changed
  • pixelplumber
    • Aug 2007
    I second this problem. I get the same issue with a fresh install of 1.4.2
    • dsipe
      • Oct 2006
      • 184
      More info on the problem:
      In fact, the problem come ONLY with filters Group->ALL and Host->ALL
      If you select a group, or a host, no errors!
      • pixelplumber
        • Aug 2007
        ahhhh....... same again with a fresh install too. (I thought I was going crazy there for a minute thinking it had fixed itself)
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          Sorry, it is a typo in the SQL statement, 'while'=>'where'. It was fixed yesterday in SVN code.
          Alexei Vladishev
          New York | Tokyo | Riga
          My Twitter
          • dsipe
            • Oct 2006
            • 184
            ok!
            can you tell us which file to modify please ?
            • jkoyle
              • Aug 2007
              Graphs Fix
              Edit the top level graphs.php line 348.
              Change the while statement to where like this:
              $result = DBselect("select distinct g.* from graphs g left join graphs_items gi on g.graphid=gi.graphid ".
              " left join items i on gi.itemid=i.itemid ".
              ' where '.DBin_node('g.graphid').
              " and ( i.hostid not in (".$denyed_hosts.") OR i.hostid is NULL )".
              " order by g.name, g.graphid");
