config location for mysql.sock?
  • agehring
    • Oct 2006
    • 49
    I'm running Zabbix (1.4.2) on a OS X system, which has the default location of mysql.sock in /var/mysql, but the Zabbix frontend wants it in /tmp.
    I've been looking through the conf files, but can't find where I would change this for the frontend.
    Thanks,
    Andrew
  • me2
    • Aug 2007
    I had a similar problem when installing zabbix recently for the first time on a Fedora 6 machine. I think the file that you're looking for is the php.ini file. In my case, my socket was located in the /data directory, so this is the configuration in my /etc/php.ini file:
    ; Default socket name for local MySQL connects. If empty, uses the built-in
    ; MySQL defaults.
    mysql.default_socket = /data/mysql.sock
    • nleaman
      • May 2010
      • 35
      optionally you can specify the socket location along with the db hostname in conf/zabbix.conf.php
      $DB["SERVER"] = 'localhost:/path/to/mysql.lock';
