If a path isn't specified for a remote command will the zabbix agent look for it in the same directory as the zabbix agent is running from ? (this is on windows).
I've found that if i dont specify a path for the key in the UserParams section then it tries the c:\windows\system32 folder. I'd like it to try the zabbix folder. I can't specify the Zabbix folder location simply because I don't know it (diff clients install it in diff locations).
