Help to install Zabbix under Red Hat 4
  • Fatima R R Tonon
    • Oct 2004
    • 29
    Hi All !
    I need some help with installation of Zabbix 1.4.2 under Red Hat Enterprise 4.
    At the Pre-Requisites screen, I have 2 problems:
    1) PHP BC math support no Fail
    2) at the bottom of the screen appear the following error message: * Uninitialized string offset: -1[/usr/local/zabbix-1.4.2/frontends/php/include/config.inc.php:376]
    I have PHP 4.4.0 installed... And I didn't find any package php-bcmath for Red Hat, only for FC6 (php-bcmath-5.1.6-3.6.fc6).
    How can I finish this installation succesfully???? Thanks for any help
    Fatima
  • knarfling
    • Sep 2006
    • 47
    Not sure how to help with this. I have just finished setting up 1.4.2 on RHEL4 and did not have this problem.
    I did an up2date php php-gd php-mysql and never saw anything about bc-math.
    I can tell you that in order to resolve dependencies, it did install php-pear, but I do not know about math.
    Are you using the default PHP, or a manual upgrade to PHP5?
    • Fatima R R Tonon
      • Oct 2004
      • 29
      Hi !
      I'm using the default PHP. I didn't upgrade it to version 5 yet.
      Are you using PHP 5?
      • knarfling
        • Sep 2006
        • 47
        No, we are using the default PHP.
        I do not understand why yours would not have bc-math and ours would. I use a minimal install and then run up2date for the programs we need. Our zabbix box does not use much else, so php, php-gd, php-mysql, mysql, mysql-devel are about it.
        • Fatima R R Tonon
          • Oct 2004
          • 29
          Solved ! ! !
          I remove all PHP packages of my server and reinstall it.
          Now it's everything working fine ! ! !
