URL Length problem: server error
  • elgoretto
    • Sep 2007
    • 28
    I'm testing Zabbix since a couple of days now, and I succesfully played with the autodiscovery and templates features. Really promising tool, I think I'll adopt it.
    But I just encountered an error while managing templates. I created a new one and tried to copy all triggers from the default SNMPv2 template to mine, and I get a server error about the url command length:
    Server Error
    The following error occurred:
    [code=HTTP_REQUEST_TOO_LONG] The HTTP request is too long. Contact your system administrator.
    And when I look at the guilty URL... ouch, yes, 5092 characters.
    http://virtualx0.labtech.pls.renault.fr/zabbix/triggers.php?hostid=10007&all_triggers=yes&g_trigg erid%5B%5D=12194&g_triggerid%5B%5D=12193&g_trigger id%5B%5D=12184& [...] &form_copy_to=Copy+selected+to+...
    Is there a workaroud concerning apache (2.0.58), or did I manage my templates the wrong way?
    Btw, is there a way to clone a template, including all its items&triggers&so on?
  • Palmertree
    • Sep 2005
    • 746
    ARe you using IE or Firefox. IE has a URL length restriction.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      FYI We fixed this in pre 1.4.3 code. Almost everything was converted to POST. You may try the latest frontend from www.zabbix.com/developers.php.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • elgoretto
        • Sep 2007
        • 28
        Thx Alexei.
        Post method is exactly what I've read that should be done, concerning this error
