frontend (1.4.2) :
1. when creating an aggregate item, key description : "Aggregate checks does not require any agent running on a host being monitored." - do not require;
also, maybe 'the host' would be better in this case ?
2. simple check tcp,port : "the serivce on the por t is down" - 'service' and 'port'
manual :
page 105 :
title : Aggregated checks
text : Aggregate checks
should be consistent (fronted is also using 'aggregate')
page 81 :
row "Key" : "For The key value must be supported" - seems that 'For' is not needed there.
page 93, row "system.cpu.util", column "Parameters" - '(default),avg5' - missing space after the comma.
manual :
page 105 :
page 81 :
