IP Address Change
  • cdm710
    • Jun 2007
    • 43
    IP Address Change
    We installed a new PDC here and changed our IP addressing scheme and now I can't reach the Zabbix server for some reason. The login screen comes up, but when I try and login you can see on the status bar it's looking for the old IP address. I don't really have a whole lot of time to be scouring that server trying to figure out what the issue is, so I would really appreciate some help.
  • jonmor
    • Sep 2006
    make sure that the network setting on your server are Okay and check your http setting for the ip he listen to.
    • cdm710
      • Jun 2007
      • 43
      It has a static IP, which is fine, and the apache settings appear correct. I don't know where it's pulling that old IP from.
      • cdm710
        • Jun 2007
        • 43
        So what else can I check?
        • brantpeter
          • Oct 2023
          Update the Zabbix server configuration to reflect the new IP addressing scheme and restart the service to resolve the login issue.
