Unable to compile zabbix agent in solaris 8
  • datakid
    • Sep 2007
    Im running zabbix version 1.4.1 and im trying to compile the zabbix_agentd under solaris 8 when i run ./configure --enable--agent that works fine but when i type make this is the error that i recieve
    Making all in zbxcrypto
    if gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -g -O2 -MT md5.o -MD -MP -MF ".deps/md5.Tpo" -c -o md5.o md5.c; \
    then mv -f ".deps/md5.Tpo" ".deps/md5.Po"; else rm -f ".deps/md5.Tpo"; exit 1; fi
    In file included from ../../../include/sysinc.h:121,
    from ../../../include/common.h:23,
    from md5.c:54:
    /usr/include/ldap.h:494: error: field `ldctl_value' has incomplete type
    /usr/include/ldap.h:1083: error: syntax error before "BerElement"
    /usr/include/ldap.h:1085: error: syntax error before "BerElement"
    /usr/include/ldap.h:1115: error: syntax error before "BerElement"
    *** Error code 1
    make: Fatal error: Command failed for target `md5.o'
    Current working directory /zabbix-1.4.1/src/libs/zbxcrypto
    *** Error code 1
    make: Fatal error: Command failed for target `all-recursive'
    *** Error code 1
    *** Error code 1
    ive googled and googled but was unsuccessful at finding the answer to this issue can someone help me out on this one
