Hi everyone,
I installed Zabbix 1.4.2 in a CentOS 5 server (kernel 2.6.18-8, Mysql 5.0.22) and the installation was ok, but when I accessed the web interface, in the screen Monitoring/Overview shows to me the following mysql errors:
* Error in query [select n.nodeid as nodeid,n.name as node_name,hg.groupid,hg.name,min(r.permission) as permission,g.userid from groups hg left join rights r on r.id=hg.groupid and r.type=1 left join users_groups g on r.groupid=g.usrgrpid and g.userid=1 left join nodes n on (hg.groupid div 100000000000000)=n.nodeid where (hg.groupid div 100000000000000) in (0) and group by n.nodeid, n.name, hg.groupid, hg.name, g.userid, g.userid order by n.name, hg.name, permission desc] [You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'group by n.nodeid, n.name, hg.groupid, hg.name, g.userid, g.userid order by n.n' at line 1]
* mysql_fetch_array(): supplied argument is not a valid MySQL result resource[/var/www/html/zabbix/include/db.inc.php:411]
* Error in query [select distinct n.nodeid,n.name as node_name,h.hostid,h.host, min(r.permission) as permission,ug.userid from hosts h left join hosts_groups hg on hg.hostid=h.hostid left join groups g on g.groupid=hg.groupid left join rights r on r.id=g.groupid and r.type=1 left join users_groups ug on ug.usrgrpid=r.groupid and ug.userid=1 left join nodes n on (h.hostid div 100000000000000)=n.nodeid where (h.hostid div 100000000000000) in (0) and group by h.hostid,n.nodeid,n.name,h.host,ug.userid order by n.name,n.nodeid, h.host, permission desc, userid desc] [You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'group by h.hostid,n.nodeid,n.name,h.host,ug.userid order by n.name,n.nodeid, h.' at line 1]
What could be this?
Thank in advanced...
Hugo Costa
Brazil - SP
What could be this?
Hugo Costa
Brazil - SP
