error to configure zabbix
  • cheesewizz
    • Sep 2007
    • 12
    Hello there
    I want to try zabbix to monitor my worsktation...
    but i have problem in installing zabbix
    I download the program
    -zabbix-1.4.2
    i follow the instruction regarding the mysql on how to install the database
    but when i use this command to configure
    zabbix-1.4.2# ./configure --enable-server --enable-agent --with-mysql --with-net-snmp --with-jabber --with-libcurl
    then press enter
    checking for getopt_long...yes
    checking for mysql_config...no
    Configure: error Not Found MySQL Library
    Please need help i dont know what to do...
    thanks
  • RohrbaGe
    • Aug 2005
    • 167
    did you installed mysql devel package?
    • cheesewizz
      • Sep 2007
      • 12
      re:
      thanks for your reply
      I dont know how to check the if i have a mysql dev but i only know my mysql server is running i used web admin to check it...
      please can you guide me how to check it...
      thank you
