Trigger related to multiple hosts actions with the undesired result
  • bbrendon
    • Sep 2005
    • 873
    Expression: ({srv2:system.cpu.util[].nodata(755)}=1)&({srv1inger[client.verio].last(0)}=1)
    Host: srv2
    This trigger is setup for srv2. If it activates and I get an alert, it says srv1 is down when it should say srv2 is down.
    Please fix. Its confusing our engineers!
    Unofficial Zabbix Expert
    Blog, Corporate Site
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Wrong! The trigger is set for both srv1 and srv2!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • bbrendon
      • Sep 2005
      • 873
      Thats fine, but how do I get it to say srv1 is down?
      This is very annoying. Is there a useful way to use dependencies? This method doesn't help much and using the dependencies in the GUI doesn't work as discussed in a previous thread. Argh.
      Help!
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Trigger name: Both srv1 and srv2 are down.
        That is exactly what the trigger suggests!
        Alexei Vladishev
        My Twitter
        • bbrendon
          • Sep 2005
          • 873
          An action fires, and a notification goes out that says srv2 is down. It never says anything about srv1. I realize when you go to the "triggers" menu in the web UI it says both are down, but I really care about srv1, which is the reason for the trigger/action. I'm not getting the important notification.
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            It is obvioulsy configured to say that "srv2 is down", just configure it differently to have notification of your choice...
            Alexei Vladishev
            My Twitter
