Agent on WD MyBook World Edition
  • orla
    • Sep 2007
    Hi
    I have tried to install the agent on a Western Digital Ethernet disk, following the documentation. "Configure" went OK but "make" did report an error.
    I am nat the in depth linux guy, so I am guessing and could need a bit of help.
    The getloadavg seems to be missing or not referenced correctly.
    Has any one an idear?
    Could it be missing SW on the device?
    Can I workaround to omit the CPU references below?
    Thanks, Orla
    Making all in zabbix_agent
    make[2]: Entering directory `/usr/local/src/zabbix-1.4.2/src/zabbix_agent'
    gcc -g -O2 -o zabbix_agent zabbix_agent.o stats.o cpustat.o diskdevices.o interfaces.o perfstat.o zbxconf.o ../../src/libs/zbxsysinfo/libzbxagentsysinfo.a ../../src/libs/zbxsysinfo/linux/libspecsysinfo.a ../../src/libs/zbxsysinfo/common/libcommonsysinfo.a ../../src/libs/zbxsysinfo/simple/libsimplesysinfo.a ../../src/libs/zbxlog/libzbxlog.a ../../src/libs/zbxsys/libzbxsys.a ../../src/libs/zbxnix/libzbxnix.a ../../src/libs/zbxcomms/libzbxcomms.a ../../src/libs/zbxconf/libzbxconf.a ../../src/libs/zbxcommon/libzbxcommon.a ../../src/libs/zbxcrypto/libzbxcrypto.a -lm
    ../../src/libs/zbxsysinfo/linux/libspecsysinfo.a(libspecsysinfo_a-cpu.o): In function `SYSTEM_CPU_LOAD1':
    /usr/local/src/zabbix-1.4.2/src/libs/zbxsysinfo/linux/cpu.c:180: undefined reference to `getloadavg'
    ../../src/libs/zbxsysinfo/linux/libspecsysinfo.a(libspecsysinfo_a-cpu.o): In function `SYSTEM_CPU_LOAD5':
    /usr/local/src/zabbix-1.4.2/src/libs/zbxsysinfo/linux/cpu.c:199: undefined reference to `getloadavg'
    ../../src/libs/zbxsysinfo/linux/libspecsysinfo.a(libspecsysinfo_a-cpu.o): In function `SYSTEM_CPU_LOAD15':
    /usr/local/src/zabbix-1.4.2/src/libs/zbxsysinfo/linux/cpu.c:218: undefined reference to `getloadavg'
    collect2: ld returned 1 exit status
    make[2]: *** [zabbix_agent] Error 1
    make[2]: Leaving directory `/usr/local/src/zabbix-1.4.2/src/zabbix_agent'
    make[1]: *** [all-recursive] Error 1
    make[1]: Leaving directory `/usr/local/src/zabbix-1.4.2/src'
    make: *** [all-recursive] Error 1
