resend config in distributed zabbix environment
  • globifrosch
    • Sep 2005
    • 74
    hi there
    i'm using a zabbix with distributed monitoring.
    Now i had a crash at the master (XEN error....InnoDB not recoverable (not the first time...) - all MyISAM db's where ok (never had problems after a crash)) and restored a backup which was 3 days old. Now there are missing severeal changes from the child node. Is there a way to tell the child node to resend it's configuration ? oder maybe there is a way to do it by sql?
    - Thomas
    ps: i'm using 1.4.2
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    1. Stop Master node
    2. Execute:
    delete from node_cksum;
    delete from node_configlog;
    3. Start Master node
    This should help.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Niels
      • May 2007
      • 239
      Originally posted by Alexei
      1. Stop Master node
      2. Execute:
      This should help.
      Good to know, thanks!
      Feature request: Make this a GUI option.
      Feature request: An option to have the entire network periodically sync all configuration.
      • globifrosch
        • Sep 2005
        • 74
        thanks alot alexei!
        • globifrosch
          • Sep 2005
          • 74
          1. Stop Master node
          2. Execute:
          didn't work.
          what i've done:
          - NODE2: deleted template linkage from host (unlink & clear), save
          - NODE2: added new template linkage to the same host, save
          - MASTER: host from node2 disappeard
          - MASTER: stopped, executed above sql, started zabbix server
          - MASTER: host didn't reappear
          Version zabbix-server/agentd: 1.4.2
          OK , it works...
          SQL needs to be executed on NODE2 and not on master.
